| That means the injector is always on. If that's the case it may be fried - they aren't supposed to be powered for a long span of time - burns out the coil. How did you determine it has constant ground? Explain the steps followed to make that measurement with your meter? Key in car on or off? etc... I'm thinking something isn't being measured right? Also use your meter (resistance, ohms setting) and measure this injector. Tell us what reading you get -- should be low in the 10 to 14 ohm range if the injector is good.
